メインコンテンツにスキップ
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
Screen is not as bright
I had to replace my complete screen ( touch digitizer and LCD screen).I. put it back together and it came on but noticed screen was not as bright even though brightness controlled all the way up.If I put it on auto bright you can barely seen the screen. I doubled check the LCD ribbon and seem to be in good. Any ideas on what could be the problem.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Not sure who you got your screen from but sometimes there's a protective film on the screen that's tinted you need to peel off. Ive made that mistake once myself.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
No I removed that
さんによる
My screeen became dim after I upgraded to 10.1
さんによる
@rouadi1 In your case I would check my settings in power settings and in the display settings. Sometimes upgrades change default settings
さんによる
コメントを追加
Its your front camera flex cable (there is proxy on it) and this proxy didnt recognize light propertly
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Arletta さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,662
