メインコンテンツにスキップ
Samsung Galaxy Note IIは、大型ディスプレイと一体型自己記憶スタイラス用に最適化されたソフトウェアを組み合わせたスマートフォンでとして知られています。
211回答 すべてを表示
締切られた回答
What part do I need to buy to fix this?
My phone got wet. It is dry now It will not boot up, but it only has a fuzzy looking lit screen that is sometimes, green, red, orange, yellowish looking. It has lots of speckles in the screen. Sometimes it is black with colored speckles in it. I never see the galaxy intro, just the fuzzy lit screen, but only temporarily. Can it be fixed and what part would I need to purchase? I already have lots of spare parts and would like to fix this one. Does it need a new mother board? I tried all the suggestions of hold down the power button while pressing the volume down button, then power with volume up, then power volume and home. It still does not boot or work. Watched all the youtube videos I could find, but nothing matches this problem. Saw the red screen of death at one point, but colors change.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You need to buy a fullset lcd which contains lcd, digitizer and touchscreen glass. Water may soaked into lcd and caused that speckles. You also might want to check all flex cable connector for rust as water vapor may not exactly went out of the phone and caused that rust. Use soft toothbrush and rub it gently to avoid damage on those connectors. Often water damage caused damage to your screen, usb or audio holes that lead to motherboard and battery. If you say your phone is completely dry (better disassemble all parts first and let it dry more as there's might still vapor) and doesn't boot, try replace battery first. If lcd is powering on, you just need to see if it needs to be replaced
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 76
