What does a red dot next to my text message mean
What does a red dot mean next to one of my text message
It means, they are using Samsung Messenger also. 🙃
このアンサーは役に立ちましたか?
You deserve up votes.
Legit just made an acct to be able to UpVote. Thx for doin' what you do. 🤙
Sometimes the dot is green and sometimes the dot is blue. I think the red dot is an indication the person you are trying to contact is traveling like in a vehicle. So that you don't constantly distract them while there driving and alternately when that dot turns green theat they are stationary and now would be a good time to contact them to hrough messages.
このアンサーは役に立ちましたか?
So could that mean I'm blocked ?
What the red dot means is that the person you are trying to send the text message to has blocked your calls and text in there security settings. I tested it and this is the culprit.
このアンサーは役に立ちましたか?
Bryan Gates is correct. Thank You.
that is wrong. because there is a red dot next to my wife's contact. but not from my ex-wife who i know has me blocked.
It is not blocked. I am in the middel a text conversation with someone who has the red dot by there name.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 9
過去 30 日: 55
今までの合計 27,698
9 件のコメント
Hi,
Not sure but it might either mean that is has been designated 'high priority' (check text settings) or that it has not been sent. (check your sent texts and see if it is missing)
jayeff さんによる
Thanks it only does it on two people in my contacts
Katherine さんによる
I have a red dot by contacts I send and receive messages from.
Cynthia Winters さんによる
Only on two of mine too
Wendy Spencer さんによる
On the tab, there is a red dot at the end of it. I am confused. Does it mean that I am not available. I would have to think. Green Means Available and red means unavailable on textnow, Right?
Aliyah Hatch さんによる
4件以上のコメントを表示
