no heat, heater hoses hot both in and out
no heat, everything 'works', heater hoses get HOT - both in and out.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like the "blend doors", or the "blend door actuator".
These internal vent doors move to adjust the cabin temperature, for the driver and passenger.
You can fix it yourself and save a lot of money. They are usually located behind the glove box, but you will have to cut away some plastic at specific locations to access the area.
I had fixed my Jeep Grand Cherokee by watching some videos, bought parts online from the same place that had great instructions that went with it, and fixed it in a few hours.
I didn't stumble onto a good video for this vehicle yet.
What year is your Caravan?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 4,022
1件のコメント
I have the same issues! The water pump bearing were bad I replaced the water pump , thermostat, and flushed the heater core temp sits where it needs to be but now I’m at a stand still until I begin to attempt the blender doors
natew189 さんによる
