メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
締切られた回答
Replaced a Cracked Display, Colors are Off
Hey all,
I purchased a replacement display for an iPhone 5s from ifixit and I did the replacement. Everything went great and when I turned it on it worked mostly but for some reason the colors are off. Everything seems really really dim compared to my wife's normal iPhone 5s. I redid all the connections but nothing is changing in regards to the colors. There are also light spots at the bottom of the screen. Also these pictures are taken with both phones at max brightness.
Any suggestions? Pictures below to see what I am talking about.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Sounds like a damaged display assembly. I can't say if you just got a bad one, or if you damaged it during the repair. You can try to send it back as a warranty, with ifixit, to see if they'll send your new one
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 55
