メインコンテンツにスキップ
A camera/camcorder manufactured by Samsung in 2012.
6回答 すべてを表示
Sd Cart - Samsung HMX-W300
I wonder how many gb samsung w300 supports camcorder, Algue If you could inform me I'm very flattered, I thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Hi,
This is from the user guide,
Compatible memory cards
You can use micro SD, micro SDHC, and micro SDXC cards with this product.
We recommend you use a micro SDHC card. This product supports micro SD cards up to 2GB. We cannot guarantee normal operation with micro SD cards bigger than 2GB.
MMC (Multi Media Card) and MMC Plus are not supported.
Compatible memory cards and capacities:
- micro SD card: 1GB ~ 2GB
- micro SDHC card: 4GB ~ 32GB
- micro SDXC card: ~ up to 64GB
When you use unauthorized memory cards, the product cannot record videos correctly and your recordings may be lost.
The memory cards released after this product was released may not be compatible with the product.
To ensure stable recording and playback, use 4MB/s (Class 4) or higher memory cards.
Micro SDHC and micro SDXC cards are a higher version of micro SD memory cards and support higher capacity than micro SD memory cards.
Use micro SD cards only with micro SD enabled host devices.
Hopefully this is of some help to you.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
256GB (With special procedure)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Danilo Seawright さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 411
