メインコンテンツにスキップ
The Keurig Mini B-31 is a compact single cup hot beverage brewer that uses Keurig's K-cup dispensing system.
12回答 すべてを表示
HELP I dropped my needle into my Keurig Mini Reservoir!
I was doing the "needle trick" and my needle fell into the Keurig. When I shook it around I can see that it is in the reservoir! :(
Does anyone know how I could get it out? OR should I not be worried about it? I am scared it will rust and get into the water.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Get tweezers and take it out.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
That's the problem, I don't know how to get into the water reservoir. It's a Keurig Mini so it doesn't have that open reservoir on the left like some of the newer versions. It's sealed off.
さんによる
Tip it upside down and shake it
さんによる
I don't think you understand. The water reservoir is sealed off. There is no open top for the needle to "just fall out"...that's what my entire problem is!
さんによる
Ohh, ok.
Well, i do not know then, sorry.
さんによる
I did the same thing. Only I dropped one of the round plastic washers into the reservoir. I'm doing a complete tear-down now and don't know what I'm doing. It"ll be a miracle if I get this thing back together.
さんによる
コメントを追加
回答を追加する
lissiekmi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 309
