Can the Dell Inspiron 5100 PP07L connect to a wifi network?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Although this is an old laptop 13-15 years old it did come with a dual-band 802.11a/b network antenna that being said it will or should work with a router that is still backward compatible with a/b band 802.11 so yes it can and no maybe it wont depending on your router. you may be able to use a usb wifi dongle to upgrade your wifi. Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 605
