メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
iPhone 4S Logic Board Replacement, Where to buy - kksilvery
Recently my iPhone is not working , Apple Logo loop when turn on then t turns off, according to my engineer , it requires logic board replacement.
I tried to restore it by putting it on recovery (NOT DFU) , it showing up iTunes error 29.
Where can i get clean imei board under 40$. Im from india if any of you have a spare or a board which do not need then sell it to me via courier or ebay etc etc.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi,
I had this same issue with my iphone 5c. It turns out that it is to do with the antenna that is near your battery. I suggest taking it out and putting it back in again. Please also clean it! So many people get it wrong but your oils from your finger can mess up the system, clean it with windex (not too much though). Also going back to your question the best place to buy is either gumtree or ebay. If you want a trusty motherboard for a little bit more money I would get if from here! At least you know it wont break. Please help me as well. Questions and comments on my page: Iphone 4 does not turn on after getting to step 9 on replacing screen, it might have something to do with the cable however I don't know. Thanks,
Max
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
hope it helps!
さんによる
Kksilvery thank you for good suggestion .... Unfortunately it dint work out for me .
Kksilvery.
さんによる
コメントを追加
回答を追加する
krishna kumar silvery さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 9
今までの合計 95
