メインコンテンツにスキップ
A laser printer series by HP for home and office use. These printers often have problems with the formatter board.
8回答 すべてを表示
Why printer goes direct to ready mode on startup and not printing
my printer is indicating ready always on start up without indicating on other functions and is dormant. what is the problem and how do i solve it?
Update (01/15/2016)
why is the printer showing the ready button only on statup
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi,
Try a cold reset of your printer
Use the following procedure to perform a cold reset.
1. Turn off the printer.
2. Press and hold the Go button.
3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
4. Release the Go button.
NOTE If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
A cold reset changes most system parameters in NVRAM to the factory defaults. A cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
NOTE A cold reset also resets all the HP Jetdirect settings as well as the printer settings.'
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
dear :sir
thank you for your co-operation
i do the cold rest steps but the printer still as before. but still the ready led still on
edrees
さんによる
コメントを追加
回答を追加する
john mburu さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 18
今までの合計 799
