メインコンテンツにスキップ
Chevroletが製造した車とトラックの修理マニュアルとサポート。
1367回答 すべてを表示
Carb is throwing gas and wont Idle
1976 Monte Carlo
My Monte is in the garage for the winter and I like to start it from time to time Just to keep the oil moving while its sitting . Today when I started it it chocked and puked a few times and ran with help on the throttle but wouldn't idle just puked a out a lot of gas . It has s 650 holly double pumper . Any Ideas as to whats going on.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Try taping the float bowel till the pins let loose and the floats re-float. This happens when you don't put stabilizer in your fuel and your engine sits for extended periods. The ethanol in the fuel causes a green sludge build up in the carb that makes the float pins stick . give the float bowels a tap with hammer not hard you just want to free them up . you may want to pull that pumper apart an clean the jets and needles and the float bowl reservoir. Hope this helps
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
Tap trick worked and I decided to put a carb kit on it so i cleaned it out and you were right about the green scale. I'll have to remember to use a fuel stabilizer after this.
さんによる
コメントを追加
回答を追加する
Robert Unclair さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 77
