メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Front facing camera not work
the phone is droped badly when i assembled whole logic board in other housing with new lcd and flex cables everithing is working except the front facing camera on image is the missing part but everithing else is on place i think. please tell me what to do... thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I never had this instance before but I think you should get your phone fixed first and then go to the store where you got your phone from. Ask them how to fix it.
さんによる
When you reassembled the phone to test it you didn't get anything over the camera by accident did you I have had occasion to get tape or glue on the lens not realizing it was covered It doesn't take much
さんによる
コメントを追加
4件の回答
ベストアンサー
i fix the board ,and now the camera is working.... there are a missing component above the screw ring, the third component from right in the first row just above the ring that i miss.
thank you all for yours time, thanks alot :D
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Wait I'm confused. Why can't you just put a new front camera assembly on there?
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
i also do a microsoldering and tht stuff but i can find a problem, i put a few new cables but nothing ....
さんによる
do you have any idea what should i do?
さんによる
i think its a hardware error
さんによる
I'm not sure which part your missing
さんによる
コメントを追加
That board looks fine in that section. Rule out bad part. Rule out software--front and rear cams are dependent on each other. After that, head to schematics--search for Cam 0 and cam 1 --follow lines, measure voltages in and voltages out. Look for missing damaged components, that's all you can do
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi .
I had similar problem with my iPhone 3 since last year .
It resolved after I updated my iPhone 4 via iTunes .
It might work orbit could be a hardware issue .
Regards ,
Kksilvery .
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Vladan Vojinovic さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,959
