メインコンテンツにスキップ
Repair guides and support for your Sanyo TV.
360回答 すべてを表示
Screen turns black after a few seconds of being turned on
I could turn on my TV and it just goes black after a few seconds. I tested and the sound still works. everything works in the background. but it just goes back after a few seconds. the light indicating it's on stays on. but I have no clue what I'm doing. I'm just a TV owner lol.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I recognize this is an old question but still has value since this comes up many times with multiple other brands as well. Since you still have audio and the screen originally lights up, this is most certainly a failing backlight. Once the screen turns black, in a darkened room, shine a flashlight at an angle against the screen. If you can still make out shapes or silhouettes, you know it is the backlight array. To replace the backlight you will have to dismantle the panel and replace the backlight strips. Sounds complicated but it is not. We would need to see the back of the panel etc. which in this case will not be possible.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nat T さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 352
