メインコンテンツにスキップ
1.8 GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.8 GHz)3MB L3キャッシュ
363回答 すべてを表示
Water Damage, Battery not charging. Worked until battery drained
Hello!
My Mum dropped some coffee on top of her Macbook Air. I managed to open it, dry it and cleant it with Isopropyl Alcohol 99%. After a few days of drying the computer booted up but I never got it to charge the battery or work with AC Adapter. It worked until the battery was drained and nothing has happened ever since.
Any ideas on where shall I start testing? I already bought a new IO Board which didn't work so it's clearly not that.
I got the schematics of the board but I have no idea where I should start testing. Does someone has any idea?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
3件の回答
Try looking up Lious Rossman on youtube. He has a whole channel explaining how to troubleshoot these problems. If you have a basic understanding of electronics then this is a great way to start
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Double check the connector for the I/O board. When replacing my upper case, I found that the pins had been bent back in my haste. I found that the magsafe connector didn't light up when this was the case.
Also, it might just be that the power button is U/S. In which case you'll need to replace the whole upper case. Not that difficult as you might think, just a lot of steps.
Cheers
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Open the bottom case and unplug the battery. It has a clear tab on it. Pull out not up. Then plug charger in and perform SMC reset. Lights on charger will change from amber to green. Normal. After Reset, should power on. Replace battery. Hope this works.
Didn't see date of OP's post.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Cristian さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 549
