Is it possible to turn off the camera sound?
The sound is pretty loud and ist not cangeable and kind of annoying. In surroundings wehere you shoud be qiet is ti impossible to take fotos.
Thanks if there is a solution.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
With update 1.2.8 you can.
このアンサーは役に立ちましたか?
Hi,
If there is no shutter sound on/off option in the Camera settings of your phone, (scroll down in the 'General' settings box that opens when you press Camera settings, as there are usually more options than is first seen) there is the option to install an app which will do it.
Here is a link for you to choose from.
このアンサーは役に立ちましたか?
I tried SilentCam Switch, with no success.
The shutter sound can not be muted (at this moment). Not in the camera settings nor in the sound -> other sounds settings.
Even when the sound is completely muted via the notification bar there is still a shutter sound.
Maybe there will be an update on that soon or you use another photo app as jayeff suggested. You might want to contact the people from FairPhone directly to see if they have a solution.
このアンサーは役に立ちましたか?
Bon et bien, avec celui-ci, c'est bien silencieux, et qq fonctions en plus...
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 5
過去 30 日: 40
今までの合計 15,746
