メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Wiiリモコンは、2006年11月19日に発売された任天堂Wiiゲームコンソールのオリジナルコントローラーです。オリジナルのWiiリモコンのモデル番号は、RVL-003です。
The arrow buttons on Wii remote don't work any longer.
The other buttons on Wii remote work fine but the up, down, right and left arrow buttons don't work. It could be a console issue because the main window shows the games and Internet icons however none are selected and nothing I do can select any of them. Sort of 'you can look, but don't touch!'
Bob
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
How can I fix it
さんによる
i have the same problem with our Wii remotes/console …. the remotes sync up with the console and turn on and if i press the plus or minus key i can scroll side to side but can’t select anything. The up down right left button doesn’t do anything. I have tried to remotes to no avail. I even bought a new sensor incase that was the problem but that didn’t change anything either.
さんによる
Did you ever figure out the problem I’m having the same issue
さんによる
same here, it is so strange.
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi,
If your Nintendo Wii Remote has sticky buttons, see the Nintendo Wii Remote Buttons Stick problem page for possible problems and solutions.
Have you got access to another remote? This will prove whether the problem is with the remote or the console. If the remote is the problem, it may be that the contacts under the arrow buttons are either oxidized or worn by usage.
Here is a link that gives a general idea of how to repair a remote. I would recommend that if you need to pry open the case (because there aren't any screws) that you don't use a small screwdriver as shown in the video. It causes too much cosmetic damage. Use a broad-bladed tool such as a 1" paint scraper. It spreads the pressure over a wider area and causes less damage. If cleaning the contacts doesn't solve the problem because they are worn by being used a lot, you may be able to 'paint' just the contact area of the rubber button with silver conducting paint, which is usually available from electronics parts stores.
https://www.youtube.com/watch?v=gVr8eLW0...
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I tried so hard trying to make the (up, down, right, left) buttons work… the method on the video did not work. Thanks anyway.
さんによる
コメントを追加
最も参考になった回答
After looking hard on the Internet I figured out that the problem was not the arrow buttons it was the sensor bar that wasn’t lighting up. The sensor on the remote is actually looking for two lights that (if the sensor bar is working) light up on the sensor bar. Since my sensor bar wasn’t lighting up, my remote wasn’t working either. The solution to this problem is to get 2 lit candles (placed about 6 inches apart) and then the remote will identify the 2 lights of the candles and the remote will work. If you don’t believe me look it up on YouTube.
このアンサーは役に立ちましたか?
スコア 5
8 件のコメント:
That totally worked!! THANK YOU
さんによる
Super!! It worked for me too!!! couldn't get the remotes to connect. Two candles and boom! MILLION THANKS!
さんによる
All I can say is WOW . Thank you , it worked !
=== Update (11/30/2021) ===
All I can say is WOW, the candle idea worked !
さんによる
It did work. Thanks.
さんによる
I created an account just to thank you! The candles saved me from throwing mine away!
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Rabbit Halo さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 54
過去 30 日: 144
今までの合計 31,991
