メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
締切られた回答
Possible to Upgrade Logic Board with Board from 15 inch MBP?
Hi,
I have an early 2011 13-inch unibody MacBook Pro with a 2.7 GHz i7 processor. I need to boost my processing speed to run some music applications better and have already put in 16GB of RAM and a 500GB SSD after which I saw big gains in speed. I was just wondering: is it possible to replace my entire logic board with a better logic board from an early 2011 15-inch unibody MacBook Pro? In other words, will it fit physically in my machine?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Your processor is packing a punch already , you could upgrade to the 2.9 i7 board but you won't notice a difference. What programs are you using that you want to boost so much?
さんによる
I'm just running MainStage 3 and Omnisphere, but could be smarter about how I'm making patches to reduce CPU usage. I usually have issues (pops and clicks) when I'm running a five-channel multi in Omnisphere or using granular synthesis and don't want to increase latency too much by increasing the sample size in MainStage.
さんによる
コメントを追加
1 件の回答
ベストアンサー
@astenzel no you cannot. Totally different size and setup.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 90
