メインコンテンツにスキップ
Screen flickering and after reboot mac stuck on booting screen
Hey guys,
I kindly ask for your urgent support on a screen/monitor issue on my macbook pro 15".
I have a macbook pro (A1260, osx 10.6.8 snow leopard) that ran smoothly until 5 mins ago when I was browsing the internet and the screen start flickering (blinking "stripes" appeared on top of the webpage I was on). It became unresponsive so I had to shut it down by removing battery.
Now when I try to start my mac, it starts up but stays forever on the booting screen (the white screen with apple logo and the loading symbol): when it's supposed to switch to the light blue blank screen just before showing my desktop with all the icons, it just remains on the white booting screen and the loading symbol stops loading/freezes.
If it weren't for the screen that stays frozen on that white booting page, i'd say the booting process is succesfull because, even screen still shows white loading page, if I press volume keys I hear the volume sound going up/down and if I press thepower button and then either press enter key or R key on the keyboard, the computer shuts down regularly or reboots depending on which key I've pressed, just as if shut down menu had appeard regularly on the screen...
I have already tried to reset pram and smc, but so far it did not work.
Could any please give me some directions on how to fix this?
Thank you so much
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Usually a white screen indicates a hard drive problem and an incomplete system load. Try booting from your original system installation disk and let us know if the problem persists,
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
First, let me thank you for your prompt and kind reply. Now i'm trying to boot on safe mode, if it fails i'll try booting from system instlalation disk. In the meantime, can i ask why, if it turns out to be a hd related issue as you suggest, the screen flickered?
さんによる
コメントを追加
Unfortunately the problem persists. Tried to boot from original disc but after some loading an error message appeared telling me to shut down computer and boot again (please see this photo where you can also see in the black background of the error message those "lines"/stripes" I was telling about earlier http://it.tinypic.com/view.php?pic=1fwod...). BTW the boot manager that allowed me to select booting from disc didn't show any weird lines/stripes. and here's a video of the white booting page i'm stuck on and you can hear volume going up and down as i press volume keys, just as if the mac completed booting and yet it's not showing desktop and all... https://vid.me/O16z Any suggestions on how to proceed / solve this problem? Thanks a lot again for the support!
UPDATE: i managed to run Apple Hardware Test and turns out my mac has issue 4vdc/1/40000003 videocontroller, which should be related to defective gpu chip that was mounted on some MBP in 2007/2008 (and then similar issues appeared also for 2011 mbp i think) for which apple ran a repair/substition program but unfortunately it has now ended. Does anyone know how much would it cost to have it repaired at an apple store? (i think replacing the whole logic board shouldn't be necessary).
Otherwise, I've read about some guys who claimed they managed to repair gpu chip (reballing it) by using heat gun and reapplying thermal paste...you guys think this would be a viable solution?
thanks a lot in advance
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
murch さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 8,312
