メインコンテンツにスキップ
Updated in March 2008 with 802.11n Wi-Fi support, the AirPort Express A1264 is a compact and portable wireless network device.
14回答 すべてを表示
My unit just quit working.
Does anyone know how to open the unit without destroying it? Once I get it open does anyone know any common problems these units have?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
ベストアンサー
Perhaps this will help you.
http://www.vonwentzel.net/ABS/Repair/ind...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
+ excellent
さんによる
コメントを追加
最も参考になった回答
The rubber bottom comes off and there are four screws. Problem is what to do after it's open. Are you getting any power to it? To open my power adapter I ended up taking a hammer and hitting it over a dozen times(This baby is tough). After opening I really found no user replaceable parts and ordered a new one in from China. It took 18 days to get, but I now have a working Airport.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
さんによる
I think you are talking about a different unit. My unit is about the size of a laptop power supply and has an Ethernet port, a USB port and a speaker port. I used it for a printer on the network or a set of exteranl speakers. It is called an Airport Express base station. There is no rubber bottom.. as stated earlier, looks like a laptop power supply (3"x 3-3/4" x 1-1/8").
さんによる
The bottom of mine say "Airport Extreme Base Station". My error, yours is the Express. fj713's link is excellent.
さんによる
To quote vonwentzel "there is little one can do inside the Express, anyway, as every component is integrated right onto the mother- or daughter-board. There are no more separate transmitter cards, jacks, etc., so there really is no reason to open the Express besides curiousity and the desire to void the warranty as quickly as possiblthere is little one can do inside the Express, anyway, as every component is integrated right onto the mother- or daughter-board.
さんによる
from China? can you give as the source?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
tom さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 13
今までの合計 5,355
