メインコンテンツにスキップ
iPad Mini 3のLTEモデル用の修理ガイドです。2014年10月16日に発売されました。iPad mini 2とも知られているiPad Mini Retinaの継続モデルです。
31回答 すべてを表示
Why is this device ghost touching after replacing the screen?
I replaced this iPad Mini 3 with a new screen from iFixit and the customer brought it back saying that it was doing things on it's own without her even touching it. I confirmed that is the case and it seems to be happening when a slight bit of pressure is applied to the lower left or right corners. I took a video if you would like to see it happen. I opened it up again and nothing looks pinched and I put some EMI tape over the home button cable, since I read that may help. ANy ideas here? I also ordered a new screen in case I have to go that route.
Thanks in advance!
Bodhi
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Have you confirmed that the cable for the digitizer is seated correctly?
Also, I have heard that a power cycle may also fix the problem sometimes.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem with an iPad 3 4G... Even when the digitizer isn't touching the frame the iPad goes crazy. I've tried different digitizers from different companies but still having problems. I know the solutions for the iPad mini 1 and iPad air but with this one i'm stuck... Anyone?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I too just posted this similar question on fixit and i'm in the same boat and no one seems to have a fix for this. We order our parts from china and are the same that many companies sell here in the states. I have contacted my supplier about this issue he stated I should try OEM original apple screen for the iPad mini 3. So on my next order I'll be ordering some. I'll report my outcome.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I think it's just bad quality batches of digitizer glass touch screen. I've been repairing many iPad Mini 3's without issue using Kapton tape as a safe measure.
さんによる
コメントを追加
回答を追加する
Mac Daddy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 375
