メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年秋に発売されたLGの大型スマートフォン。LG G3(D855)はQuad HD IPSディスプレイと1300万画素カメラを誇る。
My LG G3 wont turn on?
hi every one i need some Help please
I flashed My LG G3 with the Android 6.0 after that a mistake I used kingroot to root it then i let the Phone perfect the night
next day he wont turn On i retired battery nothing
i tried to go in recovery Mode or flash Mode also nothing took him to a repair place they said he worked like charm in 2hr then he'r we go again same problém
please i need your help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
6 件のコメント
any help please ?
さんによる
Hi,
Does it work when you have it connected to the charger? Does it show that it is charging?
さんによる
yes its charging but there is No Red Light and if i let it a hole day its get discharge and show me a screen showing 0% battery
さんによる
They probably changed the battery/charging port has the Rom you flashed might not have supported the various chips for your phone.
さんによる
so What should I do please ??
one said to me there is a problem in the Ram because of bad rooting ??
さんによる
1以上のコメントを表示
コメントを追加
4件の回答
最も参考になった回答
How old is it?
If you had it for a long time that might be a reason.
Have you dropped it at all or shook it a lot?
I dropped my iPhone a couple times and it did not turn on until the day after that.
Also when I was younger I shook my mothers iPad a couple of times and it didn't turn on either until
the next day.
Have you charged it or changed the battery?
That is another possible reason especially if you used it while it was charging.
What I'm saying is that you can either run down or kill the battery like that.
Also the more you use your phone while its charging the faster it will run out of battery's.
The last reason i can think of so far is magnets.
I know what your thinking,how can magnets have anything to do with your phone not turning on.
Magnets can screw up the circuit board and the compass on your iPhone so it won't turn on or turn on correctly and if it does turn on you will probably have problems getting to your phone home sceen
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
the Phone is 5 month Old
i dropped him Just one time it had been 4 month now
and the problem is from 1 week only
the Phone was 67% when i plugged to charge it in the night but Next day he was OFF in one word No life dont go to recovery or download Mode
i never changed anything in the phone
no my friend i never Used My phone when he where charging
Its a LG G3 D855 Model runnig android 6.0
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
my lg g3 problem is power off hate up not charjing show
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my lg g3 power off hate up and not charging show
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
dishonored さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 34
今までの合計 10,655
