メインコンテンツにスキップ
The aluminum PowerBook G4 was released by Apple to replace the previous titanium-body model. The 12" and 17" versions debutted in January 2003 with the 15" version following in September of that year.
683回答 すべてを表示
memory slot makes 3 beeps upon start up
memory works in slot one but not in slot two
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
thanks may be i will have to do that
さんによる
コメントを追加
3件の回答
ベストアンサー
You can live with one kidney or one RAM slot. You might want to put a 1 GB chip in the working slot. This machine will run OK with one gig of RAM.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Good answer +
さんによる
I've also found that sometimes when a slot won't take a full 1 GB chip it will take a lessor one, like a 256 meg. Not that much but still a 25% bump and makes use of older obsolete chips.
さんによる
コメントを追加
Having one bad RAM slot in a PowerBook Aluminum is a common problem. Unfortunately, the only way to fix the problem is to replace the logic board. You can also try testing the RAM chips in the working slot to rule out a bad RAM chip.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Does anyone know why that other slot fails? I have the same problem and it seems like the other slot is getting ready to quit. It sometime don't boot up and I have to wiggle the other mem to get it to start.
Kevin
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
bruno さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 1,416
