メインコンテンツにスキップ
The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
Why does the printing skip every 2 lines in the text?
When I try to print a page, partial letters and every 2-3 lines will not print at all. Text is not visible. I have checked the ink levels and took them out and placed again. I have also reset to manufacture settings. Still not working
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
ベストアンサー
Hi,
Have you tried doing a Printhead alignment?
Here is a link to the user guide, scroll to p.214 to see how to perform an alignment. Also check the section titled Adjusting Print Quality on p.203.
https://files.support.epson.com/pdf/wf25...
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
Once my printer also started skipping lines. It was not fixed but it skipped 2 or 3 lines. Sometimes it prints fine but sometimes it skips the lines. Even text got also prints in two lines of the same lines. One of my friends suggests changing the link as well as a cartridge but nothing helps. Even I did Align the printer but the printer was aligned even doesn’t print in a line. Finally, I change the paper as told at fix printer skipping lines and it starts printing line by line. Print quality also gets much better. It looks a bit awkward but it’s true changing of paper can fix lots of print issue and increase the life of printer as well.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mmeshank さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 25,355
