メインコンテンツにスキップ
iPad Miniは7.9 インチのディスプレイで、容量は16、32、64 GBがあります。
630回答 すべてを表示
I cracked the inside of my I pad mini
Ok, so I dropped my I pad mini. And I broke the inside of the screen cause there is a hardly noticeable green line at the corner of the I pad, and there are no cracks in the outside. I also have this grayish bar on the side of my I pad that sometimes changes colors, which is making the lighting of my I pad really dim and I can hardly see. Other than that the Ipad still works fine. How do I fix this, do I need to take apart the I pad mini? I have tried resetting it, and restoring it but they both do not work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
最も参考になった回答
It's sounds like your LCD might be damaged. You would have to take the screen off to replace the LCD, with the iPad mini. I would try very hard to not damage the glass or digitizer so you can reuse it, many cheap after market screens with silver edges will only cause you problems. Also disconnect the battery and when doing that make sure you disconnect from the battery side if you go from the other side you will damage the back light fuse. Check out website from iPad rehab they have a great guide for you to follow.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Some people stated that hitting the I pad on a hard surface might help, is that true?
さんによる
Hahahahaha. You're funny
さんによる
コメントを追加
If the screen is cracked, then it can be replaced. Yes, it does need to be taken apart.
There are lots of helpful guides and walkthroughs on this site to help you do this.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
So I can fix this problem by myself?
さんによる
Is it the touch screen's problem or is it the inside of the I pad that needs repairing?
さんによる
It is something you can do yourself. If you're getting brightness issues too, the LCD probably needs to be replaced as well.
I believe you can get a replacement screen which includes all three parts together; LCD, digitizer and glass panel. And to make things easier, you can also get one that has the camera and home button already attached. If you got this, it'd be a simple task of swapping the two screens, old and new. Minimal disassembly.
さんによる
Are you sure I didn't break any wires
さんによる
コメントを追加
My iPad fell out of the case when I was walking and it cracked the left side corner close to the home button. What I'm worried about is that it left a small hole where I can see the hollow part of the iPad... Please HELP!! Can it be replaced? Is it cheap?!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It can be fixed relatively easily but only if and only if it is an iPad 2,3,4, mini 1 or mini 2, or Air 1. All models after that are difficult to repair because of Touch ID and such. The hollow part is just the inside of the frame of the iPad.
さんによる
コメントを追加
My ipad is cracked on the inside and frozen.When i tried to update it i could nt put in my password and i dont know what to do.Please help me
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
You can get it replaced. Or, you can get the screen replaced by opening it, and you can back up your data, and clean out the iPad like you just bought it from the store. Put your data back on the iPad.
さんによる
コメントを追加
回答を追加する
Anonymous さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 4,156
