The microUSB port to charge my pill is broken.
The USB port to charge my pill is loose. Can it be fixed, if so how?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here's parts...
https://www.google.com/aclk?sa=L&ai=CLZ0...
This appears to be labor
http://m.youtube.com/watch?v=4LS3ZSpT2Ug
Basically your charging port is worn out, and you need a new one. It can be soldered back on. If you're willing to do the work
このアンサーは役に立ちましたか?
explain how i do this
You'll need to remove the logic board, then desolder the bad charging port, then solder the new one back on. Didn't realize the video I posted was so terrible
Lauren mail in your beats pill and will solder the part in for you grios.g3mobile@gmail.com
このアンサーは役に立ちましたか?
Don't be fooled by the parts, I bought parts similar from eBay & it was not compatible.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 19,923
1件のコメント
https://www.youtube.com/watch?v=fNGB8KVa...
nicolasb さんによる
