メインコンテンツにスキップ
2015年3月に発表され、同年4月に発売されたGalaxy S6はGalaxyラインの中で最高のデバイスです。端にカーブが施されたスクリーンはGalaxy S6 Edgeです。
487回答 すべてを表示
phone is on but screen is black
My dog knocked my phone out of my truck and when the phone hit the pavement it cracked the front screen. The phone is still on but the screen is black. I can hear when someone texts me but I cant make the screen come on. I have tried restarting it by hitting the power button, power +volume+ home buttons, and power+volume button and the only sign of life on the screen is the little light in the top left corner indicating I have texts, emails, etc. Am I going to have to replace the entire screen?
I'm thinking its an LCD issue after some research. Can I replace the LCD and just deal with the cracked glass or do I have to change both?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 26
20 件のコメント
I have the same issue it was a very soft fall however the cellphone is on but completely black.
さんによる
You may want to check the displays connection on the motherboard. You may have a loose connection due to the drop. Try reseating the displays connection to the motherboard. If the connection is properly seated then odds are your current display is damaged and will need replaced. The guides on this site can help you through this process.
さんによる
I had the same issue, i even had a spare digitizer from old phone and that still hasnt worked. I did all the restart power up and down, hold home button etc, and my phone doesnt even go into recovery mode (no screen vision in any mode), what could be the possible cause if its not the digitizer or in a deep sleep? Could it be a mother board connection? Phone does power on and all the buttons light up etc, volume can be heard so i will try to clean the connections again inside.
さんによる
did you get it fixed? because I have the same problem now and I need my phone fixed, because I very important information on there.
さんによる
Hello. I don't know if anyone could help me with this question but it would be appreciated if someone could. The glass of my daughters samsung S6 was cracked but still working. She put it in a shop and they said the digitiser was also cracked but held together by the glass and it was only upon them removing the glass that this support held it together and now there is no display whatsoever. Could this be the case that it was only functioning still because the cracked glass was holding it together or has the shop damaged it further. Thanks.
さんによる
15件以上のコメントを表示
コメントを追加
11件の回答
ベストアンサー
I would recommend replacing the whole display. The LCD in a display by itself usually is not much cheaper than the whole display. Sometimes it's hard to find only the LCD alone. Also are you sure the digitizer wasn't damaged? The digitizer sits between the glass and the LCD and controls touch function. If you are unsure if the digitizer is damaged then your best bet would be to replace it all. Also replacing the whole display is way easier then trying to separate the parts of a touch screen display. Especially if your glass is cracked badly.
このアンサーは役に立ちましたか?
スコア 9
9 件のコメント:
If I don't replace my bad display, can the Sprint employee transfer my valuable pictures etc with a blank screen onto a new phone?
さんによる
Can I do it myself without taking the phone apart?
さんによる
@beccaaaa, You can do it yourself but unfortunately you will need to take the phone apart to be able to access the displays connection to the motherboard. If you wish to attempt it yourself this guide can assist you on replacing the display. Samsung Galaxy S6 スクリーンの交換
さんによる
can i change the screen myself? or do i need a professional? because when you buy the actual glass screen they sell the supplied to do it yourself. Is that possible?
さんによる
so, im able to unlock my screen but my screen is still black. I know i can unlock my screen simply because i have an unlock sound and as i swipe upwards i hear the unlock sound and feel the vibration as well as my touch feedback and i can even switch the volume up and down (which im not able to do if the screen is locked)
what should i do?
i have the G920T model
さんによる
4件以上のコメントを表示
コメントを追加
They can technically be separated, but honestly if you are going to replace the display they almost always come with new glass. They are glued together so you shouldn't have a problem finding both together ready for installation.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
When you are experiencing the frustration of a broken Samsung phone screen, please don’t panic! Find my phone is the easiest way that can help you get back your data. It is workable as long as you have a Samsung account on the device. Here are what you need to do:
1. Go to the Samsung website and click the Find my phone button.
2. Log in using your Samsung account you used to have on your phone.
3. All the options regarding using your smartphone remotely will be available on the screen.
4. There will be an option on the left-hand side of the screen to unlock your screen remotely.
5. Connect with your USB Cable and KIES will allow you access to your files.
If you realize that your Samsung Galaxy S6 phone was broken or blank screen of death, you've got a decent chance of getting the data back. Here is the guide teach you how to recover photo files from broken Galaxy S6.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It is better and easier to replace the whole screen replacement. The lcd screen, touch screen and front glass are already bonded together tightly by strong adhesive, so it is hard to separate any one of them just by DIY repair work. Though it is still possible to do that, you may damage the lcd screen or touch screen during the process.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
How much does it usually cost?
さんによる
コメントを追加
Update (04/21/2017)
I tossed my phone to the side and it hit the rock on my wall and now my screen is black but I can hear everything and every time I turn it on I see flash in the top right corner
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Same problem. . .help!
さんによる
コメントを追加
Hi I cracked my screen in the top left hand corner but my screen is black I can here the volume button and stuff I've tried resetting it and still black screen what do I do?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
what should i do?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi I cracked my screen in the top left hand corner but my screen gone black I can here my message the blue light still works I've tried resetting it and still screen is black have I damage it? Inside the phone what do I do?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If you realize that your Samsung Galaxy S6 phone was broken or blank screen of death, you've got a decent chance of getting the data back. Let go
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I've had my Samsung S6 for about 2 years now i do not have one crack, I barely drop it and when i do its in a wallet case. Today my phone went blank after being on all day. What happened?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
J3 screen got smashed so i've changed that along with dig equalizer but the little bit where you clip it on to the mother board has both broke off (little plastic bit top and bottom) so it dont clip in but i've mananged to make it sit but still no display showing up. Can hear it bleep when chargers connected but no lights show up!? Any ideas on how to fix this issue please?
さんによる
コメントを追加
my phone died and when i charged it for a few minutes and turned it on my screen was just black but i can still hear the notifications
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Virgil さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 23
過去 30 日: 97
今までの合計 143,287
