How do I turn on panel ligh?
My microwave (GE JVM3160RF2SS) works but I can't get the panel to light up and don't see a switch.
Any ideas?
I added a small number button to the ON on the panel to turn on light in the dark…
このアンサーは役に立ちましたか?
Can you please explain how to do this? The panel on my microwave has no “On” button except for “Timer On Off”
How & where did you add a button to light things up?
Was the number button solar so it lights up in the dark.
The model I purchased does not have an ON button. Has a Cook Time button.
What he means is to put some distinguishing mark on the button that controls the surface light (under microwave light) to make that easy to turn on and then the light from that aids in seeing the control panel. It is a good workaround to a very stupid design flaw on GE’s part.
There is no way to light the control panel, bad design. Well I discovered a way to light manually and in a way that provides Incredible light with 2 settings. Even better, the microwave’s looks as if the light is part of the appliance. see photo. Easy to do, cheap and battery run. Photos below. I’ll be happy to describe how I did if you want to know.
このアンサーは役に立ちましたか?
YES!...please explain how you lit up the panel...Thank you!!
You can purchase. These from Amazon. Get heavy duty small magnets “”monkey” magnets great. Amazon. Turn light on side, add 3 magnets to bar, match up on microwave. See photo above. Looks great, works great.
Under Cabinet Lights with Remote, Magnetic Rechargeable Under Counter Closet Lights, Wireless Night Light Bar Stick-On, for Kitchen Wardrobe Cupboard Stairs...
My problem is you can't see the clock in the daylight to know how many minutes are left for cooking, or for that matter did you put in the correct minutes and power
過去 24時間: 2
過去 7 日: 30
過去 30 日: 129
今までの合計 21,415
not talking about surface light talking about the control panel light so i can see the buttons to push have to turn kitchen lights on high to use this product
tina さんによる
I have the same problem and I have talked to numerous GE people and they have no solution to the problem. Their only response is basically that is the way it is. I'm not happy with their response. They should provide a solution.
Darlene Moynagh さんによる
Obviously, flawed design by the same person that fashioned the Titanic
mdsbarry さんによる
Totally agree. Microwave looks nice and is running well BUT is extremely hard to operate when you can't see the display.
Linda Abboud さんによる
Panel display impossible to see . My last GE product.
Their stock price reflects the company downward spiral.
randresid さんによる
20件以上のコメントを表示
