Why my laptop not coming on?
laptop not coming on after allowing it to power up for one plus hours. All I receive is a quick flash on for about 2 seconds and off again.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
After allowing my computer to charge for 1 hour or more, my computer on light; lights up only a few seconds and the screen stay black. No sign of power.
このアンサーは役に立ちましたか?
Hi, I hope this helps.
Try taking the battery out, and disconnect the power adapter. Then hold in the power on button for 10 seconds to get rid of any residual power. Then connect the power adapter and then push the power on button. If this works, try putting the battery back in and from the system tray see if it shows it charging.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 106
2 件のコメント
carl, when you say "allowing it to power up for one plus hours", what do you mean by that? Is anything showing? any LED's working? What have you checked? Tried a different boot device? Can you access anything? Tried to access the BIOS on startup?
oldturkey03 さんによる
probably has something to do with putting the battery in the fridge
Jimfixer さんによる
