メインコンテンツにスキップ
モデル番号A1286、発売日 2011年2月/2.0, 2.2もしくは2.3 GHzクアッドコアIntel Core i7プロセッサ
586回答 すべてを表示
締切られた回答
White Fade on screen occasionally
When i'm working on a job for 35 minutes continuously i'm getting a white shade on screen ( image : http://i.imgur.com/MGHb2eY.jpg ) . When i close the LED and reopen after 3-5 minutes it will became normal .
I've taken the laptop to the service center . and replied as below
"Checked and found Shades on display at times. Tried System
management controller and Pram- no go. Checked with known good external OS- found same. Checked with a known goo external display found display getting without any shades, did apple service tool test failed in display test. Hence the macbook having display related issue need to replace LCD,DISPLAY CLAMSHELL,15.4",GLSY for addressing the issue. Customer denied paid replacement, Hence returning back the device with out repair "
. I'm really thinking why ? when i close and reopen the lap everything goes perfect .
Please reply the problem is with LCD or LVDS cable .
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Take it either to an Apple store or an ASP and have this test run on it: https://www.apple.com/support/macbookpro...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The main MLB of my mac is already got replaced by qualifying this program. But it's not related with GPU. There was a video issue and got stripes on screen and it remains permanent. After replacement of the MLB I got this issue
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 300
