メインコンテンツにスキップ
The Acer Aspire One model D225E is a 10.1-inch netbook that features an ultra-thin and lightweight design with a powerful battery making it ideal for everyday computing on the go. Also known as Acer Aspire One D255E-13639.
20回答 すべてを表示
締切られた回答
Why my netbook screen turns to red?
I have my netbook ACER DC22 DCkk which was I bought a few a years ago. When I opened it the screen turn into red with a frizzy lines of dashes. I don't know what's the problem with my netbook, should I replace my screen with a brand new one? or there is just a problem with the connection inside?.. I need your answer please.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It sounds like it is a damaged connection of some sort.
If the the screen was the problem, you would have dead pixels or visible cracks in the image.
Look at the hinges of the device, often if they are damaged then that is where your locate the issue
I haven't had the best luck in working on this kinda problem, but anything is repairable if you want to put the effort into it.
Have you tried connecting to an outside display? Then you rule out a software glitch.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 106
