How do you calibrate the screen?
When I try to tap my screen it'll select something else
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Check if there is a Touch and Hold Delay setting in your phone. If there is, set the option to short.
To find Touch and Hold settings, go to:
Menu > Settings > Accessibility > Touch and Hold
このアンサーは役に立ちましたか?
I already tried that, it didn't help.
Hi,
As a test, rotate your phone 90 degrees (so that it is in landscape mode) and see if you have the same problem. It may be an area of the digitizer that is faulty. Alternatively, backup your phone and perform a hard reset. This should restore your phone to factory default condition.
I tried to reset and everything still doing the same thing might be calibrate I have not try it yet
I got problem with my phone as well done everything but! No change with key pad?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 15
今までの合計 9,136
