メインコンテンツにスキップ
Released on October 1, 2013 the BLU Studio 5.5 is an unlocked Android smartphone with two model types being the D600 (single SIM) or D610 (dual SIM).
82回答 すべてを表示
Comes on but is stuck on "BLU bold like us" screen.
Turned phone on and it comes on to the "BLU Bold like us screen." Goes off and continues to repeat the same thing over and over.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 18
9 件のコメント
my phone started turning off and kept doing the same thing and its only showing the blu screen logo... and does this none stop...please help
さんによる
it only has factory mode, and it doesn't give me 2 options...help
さんによる
My blu phone is frozen on the start up it only showing logo
さんによる
Forgot the pin open on my phone what do I do I'm going to disable do I need to use my phone can you show me how to open it thank you
さんによる
when i turn on the phone and hold power and both volume butten and it does nothing what is my problem
さんによる
4件以上のコメントを表示
コメントを追加
4件の回答
最も参考になった回答
try this and report back
1. Pullout the batter and wait for about 5 seconds then reinsert the batter
2. Press and hold Volume Up + Volume Down + Power key for some seconds.
3. When you see a menu with two options, remove your hand from buttons. Then hold down the Volume Up to enter Android System Recover.
4. Select the "Wipe data / Factory reset" by using the Volume buttons and press the Power key for confirmation.
5. Choose "Yes--delete all user data". Use Volume Down to scroll and Power button to select.
6. select "reboot system now".
allow the phone to reboot it will take some mins to initialize but not forever.... report back with if not succeed.
i will show u how to flash the phone
このアンサーは役に立ちましたか?
スコア 4
9 件のコメント:
this phone is a blu studio 5.5C
さんによる
did you try the above procedure?
さんによる
i did n it just show up to half way turning on
さんによる
when I hold down the volume and power and menu button it comes up factory mode and gives me 8 options
1. essential test
2. PCBA test
3.full test
4.item test
5.test report
6.signaling test
7.GPS
8. Reboot
I go down to reboot and it still gets stuck on the BLU logo it worked fine this morning then it froze so I took the battery out and restarted and now it wont go back to normal.
さんによる
it did nothing to my phone that instruction is &&^& up mn I'm just a poor kid can't get no more phone
さんによる
4件以上のコメントを表示
コメントを追加
It comes on and stuck on bow like us
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It comes on and gets stuck on blu
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I can't turn on my tablet
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
回答を追加する
kimberlyragan35 さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 52
過去 30 日: 175
今までの合計 10,664
