メインコンテンツにスキップ
The Acer Iconia Tab A200 tablet was announced in January 2012 and features a 10.1″ capacitive touchscreen. This page is the gateway to troubleshooting information and repair guides for the Acer Iconia Tab A200.
13回答 すべてを表示
Tablet is stuck on "iconia tab".
My Acer tablet turns on but when it gets to "iconia tab" it stops and doesn't go any further. I turn it on the acer logo comes on then the bubbles then the "iconia tab"comes on and it stops and goes no further.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi,
Try a hard reset on your tab.
Warning : a hard reset will erase all downloaded apps and user data and restores the tab to factory default condition
Here is a link which shows you how to perform a hard reset. Scroll down and try the third (3rd) method shown in the link first (1st) as it may reset your tab without deleting anything . if it doesn't work try the first (1st) method.
Before you try any reset procedure ensure that your tab's battery is charged or has been on charge for what you think is a reasonable time. If you think that it would be low allow 1-2 hrs . Also do not perform a reset with the charger connected.
http://www.hardreset.info/devices/acer/a...
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
May tablet acer A200 stock at acer logo
さんによる
Hi, Did you try a hard reset as shown in the link?
さんによる
コメントを追加
Power + volume down while lock button is in the locked position. Once tablet vibrates move lock button to unlock position, and then release the power button. Use both hands. If it gives a bootloader error in red letters, repeat the steps until it takes. This took me about 15 consecutive tries before it finally reset the tablet.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
My acer tablet it tunes on and its stuck on the date and hours
さんによる
It gives me a green robot
さんによる
Then it falls on it’s back
さんによる
コメントを追加
回答を追加する
Gloria McCall さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 15
今までの合計 6,806
