Webcam and Bluetooth not work in Linux Mint
i have Dell Latitude e6410 and system Linux Mint 17 but Webcam and Bluetooth not work ???
Follow the steps and you might solve the problem.
- make sure the hardware devices are connected with your machine correctly
- check in the device manager if your machine already recognize your devices
- check if there is a device driver you need to update. Using Driver Talent, it would detect the driver problem quickly. Also it could help you to solve all problems related to drivers.
Go have a try. Good luck.
このアンサーは役に立ちましたか?
Hello..
Following are some possible reasons and solutions to Bluetooth issue:
* Connect to a Dell Bluetooth Device From Your Dell Computer
* Download and Install the Latest Dell Wireless Bluetooth Adapter Driver
* Download and Install the Driver for a Bluetooth Wireless Keyboard and Mouse
* Bluetooth Adapter Problems After Changing From Microsoft Windows Vista to XP
* May be there is Problem With the Dell BH200 Bluetooth Stereo Headset
For more hacks please refer to Dell Latitude e6410 Manual.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 1,253
