メインコンテンツにスキップ
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548回答 すべてを表示
Boot gets stuck on the gray screen before usual desktop appearance
Hi there,
my iMac suddenly stopped working (no cursor movement, no keyboard feedback, nothing), got stuck and I rebooted it manually.
After that, the boot process ends and gets stuck on a completely gray screen, after the startup sound, apple and loading bar.
I tried almost all software solutions (NVRAM reset, HD Recovery, incompatible .kext deletion).
The only way I'm able to boot the iMac is in SAFE MODE.
During summer I noticed some graphic glitches, that's why I believe the problem is hardware related and caused by GPU or something related to graphic.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Think about it. If it boots in Safe Mode, it's not a hardware issue.
UPDATE: 12-22-15
I looked at your link. They're guessing. Set up an external startup drive and install a clean system and boot from it. See if the problem persists.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
After some readings I understood it's about advanced graphic drivers that Safe Mode doesn't use. Any fix for it?
さんによる
What operating system are you running? Can you give a link to this reading?
さんによる
Yes sure, for example this: http://apple.stackexchange.com/questions...
I'm running El Capitan.
Thanks
さんによる
Did it do this with a lower operating system?
さんによる
I have a similar situation except it starts only in recovery mode. I format the the original portion, instal EL Capitan again but same results. I tried to boot from external hard disk, but it didn't work either. Hard drive test in recovery mode showed a healthy OK hard drive. Not starting in single user mode, Not starting in diagnostic mode, not starting from external hard disk. What could it be? Thanks for any suggestions.
さんによる
コメントを追加
回答を追加する
Luca さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 275
