メインコンテンツにスキップ
Repair guides for feature cell phones manufactured by LG. This category is for phones not using an Android or Windows operating system.
Cant swipe to answer incoming call
Incoming calls on my lg 3 phone are almost impossible to answer. The screen doesn't recognize the swiping motion and freezes up. I also have a red border around the outside edge of screen.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 30
21 件のコメント
Thanks for the help. I thought the darn thing was broken. Much appreciated.
さんによる
A friend of mine explained that a mobile phone touch screen is heat-sensitive. He suggested blowing on your fingers before swiping the dot to answer. Not perfect, but a decided improvement.
さんによる
In order to answer a LG Rebel 3 the Accessibility Options Switch on top should be "ON". All of the Switches below it should be "OFF" (including another "accessibility" switch).
さんによる
On the LG G5 select - Accessibility - Dexterity and interaction - and switch on Touch and hold for calls. Answer or decline calls without swiping
さんによる
i have an LG k4 2017 and i can not answer any calls ,i press the green button and it says swipe the screen but when i do it cuts the caller off can anyone help me solve this please
さんによる
16件以上のコメントを表示
コメントを追加
7件の回答
ベストアンサー
Hi malissa,
Check whether talk back feature turn on your phone
  • In Settings > Accessibility, select Accessibility
  • Set the switch off
Red edge can be removed turn off the developer options
In Settings > developer options > "uncheck all"
このアンサーは役に立ちましたか?
スコア 11
9 件のコメント:
"Set the switch off." What switch???? What to do here is not at all clear.
さんによる
I agree with Ben Myers.
さんによる
I have an LG Stylo 3 I have to swipe to answer and it's not recognizing my swipe. I'd much rather change it to another way of answering my calls. Is there a way of changing it?? Can someone PLEASE help me?? I'm missing so many calls...
さんによる
I found that I have to hold my finger on the green dot for a second before swiping and then swipe out just an inch or two...it works every time for me
さんによる
I'm having the same problem. I will try what Walter said. Thank You.
さんによる
4件以上のコメントを表示
コメントを追加
最も参考になった回答
I have an LG K7. Think it's the Android Lollipop 5.1 .Rarely it would answer, sometimes not. I tapped and swiped the icon repeatedly.
Never read the instructions. Turns out I have to place my finger on the ringing icon and keep my finger on the screen as I move the icon to the right, or probably anywhere on the screen. Just tried it four times, worked every time. So, unknowingly, sometimes I was doing that and sometimes not. That's why sometimes it would pick up and sometimes not.
Hope this helps.
このアンサーは役に立ちましたか?
スコア 15
14 件のコメント:
Excellent - the "swipe" instruction on the screen is so misleading, but this post was so clear and correct. Thank you, thank you.
さんによる
Pretty sad when you can't complete the most basic thing you want to do with a phone...answer it! Thanks for the very clear fix to an important problem.
さんによる
Thank you so much! This solves a problem that was drivigng me (and those who called me on my mobile) nuts.
さんによる
It's beyond belief that there are no instructions WITH THE PHONE when you first set it up on how to answer it. This is engineering arrogance to the max.
さんによる
I agree it's extremely ridiculous that such a basic task was designed to be so difficult. I spent hours trying to find and configure a different Application for my elderly parents. We kept thinking the problem was that they are just two elderly to understand, but then I realized-this is just an idiotic design problem
さんによる
9件以上のコメントを表示
コメントを追加
Go to Settings…..Accessibility……Motor & cognition…..Touch and hold for calls. Turn on to allow answering calls by touching the Answer button without swiping
このアンサーは役に立ちましたか?
スコア 8
6 件のコメント:
My phone does not have accesibility or cognitive under settings
さんによる
Thank you Skpotthast .. finally a 'fix' that works!
さんによる
THIS is what I was looking for! Thank you! I haven't tried it yet but it makes perfect sense. Us older folk have trouble with touch screens because our hands tend to be dryer. My previous phone wouldn't answer by swiping but I could press the center button to connect. My new phone has no physical buttons. Thanks again!
さんによる
that solved the problem for me, thanx, i almost bought a new phone because it was irritating me so much!
さんによる
After years of frustration with my LG phones I finally know the solution. Always just figured it was just me that couldn't answer the phone.
さんによる
1以上のコメントを表示
コメントを追加
I'm having the same problem. Went to the store, tried it in there and I could answer.
Went home. Instead of swiping I held my finger on the green dot it worked. in the store. However, at home I pressed the green dot and didn't work. This is ridiculous. I have to call back every call. Luckily, I don't get too many. Any suggestions????
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Just hold your finger on the dot for a few seconds and then swipe and it should work.
さんによる
This is ridiculous can't answer phone
さんによる
How do you answer the phone? LG Q6 If anyone knows would appreciate an answer
さんによる
Maybe we should look into getting our money back, and have a Lawyer be the front man.
I don't want to say the big word (S). This has caused stress for me, to the point where I want to destroy my phone!? , and I am not violent.
さんによる
コメントを追加
I have an LG G6. I solved my answering problem. Settings; Accessibility; Dexterity & Interaction; Touch and hold for calls.
Now I can answer or decline calls with a touch or tap. Hope this helps someone. Missed a lot of important calls. Barb Madison 11.24.19
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
YSSS! This definitely works! Thanks! No longer frustrated 😤
さんによる
Not when you cannot swipe up to put your pattern in to use your phone
さんによる
コメントを追加
I went from Samsung to LG. For over a year, I couldn’t answer calls. I had to call back everytime. The answer button doesn’t work. The phone says swipe to outer ring to answer. That doesn’t work. Oh. Hold the button. I went to settings, accessibility, 2 finger swipe up to answer. 2 fingers swipe down to hang up. My fault. I should have made time to figure this out. The solution is, go back to Samsung or any other company. Have you heard? LG is leaving the phone business.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Ah, my previous solution didn't stick. THIS works for me: before swiping to answer, press and hold the answer button for 1 second, then swipe before letting go.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks for the tip. I tried this and it worked the first time but never again.  About ready to toss this out the window.
thanks for your help….
さんによる
Thank you but that won't work see comments
さんによる
コメントを追加
回答を追加する
Melissa さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 137
今までの合計 87,553
