Screen only works when pressed on at certain spots
My laptop screen has been messed up for a few months now(out of warranty). The screen randomly stopped working, it turns on but the screen will grey, no response at all. I already diagnosed it as a LCD/connection/motherboard problem, not video card. If I press the screen in a certain way it will work until my finger is off. If I reseat the LCD by unscrewing and replacing it on the laptop lid, the special spot might change.
I used to "fix" the issue by using folded up paper to apply pressure to the bottom of the screen(which was the sweet spot at the time for a few weeks) until the spot changed for good and now requires more pressure than before to make the screen display properly. The folded up paper doesn't work anymore. I have already tried reseating the cable a few times just to see if it was a bad connection but that didn't change anything.
I'm looking for a more permanent solution other than buying an LCD screen. New screens cost around $70 right now and I would rather buy a completely new laptop than waste more money on Toshiba. I personally would've never bought a toshiba laptop but my father bought it for me to use at college even though I would've picked a better model/brand.
Is there a way to repair the screen? Does anyone else have a creative way to apply pressure the screen without me needing to use my finger?
この質問は役に立ちましたか?
2 件のコメント
I have the same laptop, and the same problem. Did you ever find the solution?
Renee M さんによる
i replaced the HP envy LCD cable but still same problem. Using a nail clipper on the bottom to keep screen bent in a bit . works as long as nail clipper is in, but not really a solution. before i replaced the cable i could not get the screen to work at all. on my way to Costco to get new laptop. not worth spending money to repair as laptop Is 5 years old. this was my first hp laptop . we have had 5 dell laptops with no issues except that they are all outdated
john boich さんによる
