screen shows everything double. What can I do?
i left my phone for a few minutes on the sofa and then when i come back the screen shows everything doubled.
Steps
1. power off button on the phone, press it
2. check the pop up on the screen (power off, restart, airplane mode, silent mode, VR mode)
3. Tap on the VR mode.
Bingo! problem solved.
このアンサーは役に立ちましたか?
very good answer and simple but very useful
This answer saved me.. thanks a lot
I dont have vr mode ,what to do,?
When you press switch off button... one extra message is displayed i.e. "VR Mode is ON".... just select that option... you will get back the original screen
このアンサーは役に立ちましたか?
Where is vr mode located
I freaked out when it happened but I turned it off. Then took the battery out and light pressed on the back where the battery sits. Put the battery back then turned it on then, it was fixed
このアンサーは役に立ちましたか?
You can't fix it with the apps or in the settings. You gotta repair it or simply just buy a new one🥲
このアンサーは役に立ちましたか?
過去 24時間: 9
過去 7 日: 59
過去 30 日: 261
今までの合計 23,572
8 件のコメント
I have the same problem for a LG Stylo 3 that was stepped on.
April Smith さんによる
did u fix it i got the same problem and same phone
Jing Jing さんによる
Swetha Thomas さんによる
no my phone fell on the groud
zyasiamorgan5 さんによる
Does this drain my battery?
Nancy Yengel さんによる
3件以上のコメントを表示
