Replace touch screen for a Samsung Galaxy S6 Edge Plus.
Front glass is cracked. How do I replace it? Where do I get the part needed?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Here is a link to a video which shows most of what you need to do. Hopefully it will be of some help.
https://www.youtube.com/watch?v=eNO_feON...
Here is a link to just one supplier. It is not a recommendation either way to use them. Do a google search for more.
このアンサーは役に立ちましたか?
The lcd screen, touch screen digitizer and front glass are already bond together by strong adhesive when it was factory manufacture. It is possible but extremely difficult without special equipment like a hot plate to remove the glue on the glass. Whilst you may also damage the touch screen. The much more safer solution is to replace the whole lcd screen with digitizer instead of replacing the glass only.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 10,351
