メインコンテンツにスキップ
Huawei Mate 7(Huawei Ascend Mate 7とも呼ばれる)は、2014年10月に発売されたファーウェイ製のAndroidスマートフォンである。機種はMT7-TL00、MT7-L09、MT7-TL10、MT7-CL00。
19回答 すべてを表示
MT7-L09 lcd replacement no working
Hello,
today i wanted to repair an lcd screen on the phone huawei mate 7 model L-09. When i tested the new lcd screen, it only shows the logo and then went black. When i recconect the old one(lcd with broken glass) it goes normally in the menu. I ordered a normal lcd from ebay and now i am wondering if there is a difference between models L-10 lcd and L-09?
Does any one has any idea of why is that happening?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
5件の回答
It is best to use original part, try returning it saying it didn't work then get the right one. Should work fine After that.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Please let us ignorants know where MT7-L09 replcement screen sells.
さんによる
Where can I get the original replacement part, ?
さんによる
You can buy any replacement parts for this phone at http://www.etradesupply.com/huawei-ascen...
さんによる
コメントを追加
L-10 lcd is the model Huawei sale in china
L-09 is for Europe.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
But why noone on ebay sell the TL-09 model lcd??
さんによる
コメントを追加
I have also a huawei mate 7 model L-09 and i have broken the screen.
It s very difficult to find this screen.
There is a lot of screen for TL10.
Do you have repear your phone ?
Raspigaous
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello.
I was able to get my phome working using an LCD screen from the MT7-TL1 model.
You need to use the LCD controller chip number on the defective screen to find one that would work.
The chip under the green sticker in the lower left corner of the broken screen said 1 on mine. I had bought the TL10 LCD also but that had a 2 on it and didnt work.
Once I used an LCD screen with a 1 on the controller chip, it worked flawlessly.
I used ebay for mine. Cost about 80$ US max because I got the frame also. It's about 60$ without the frame. Free shipping.
Hope I helped you guys out.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hi there!
Tnx so much Im sitting with the same problem... Broken L09, can only find TL10 screens for sale... Can anyone confirm 'Emm's' solution with the number at bottom left worked? Alternative solutions?
さんによる
That "chip in a corner" is Synaptics touch controller and has nothing to do with display working or not since it only handels touch function. My guess is if replacement lcd isn't working it is DOA and one should request another or problem isn't in display but in display controller or "graphic card" if you wish. Buying cheapest replacement isn't allways best move, opt for one with good buyer feedback.
さんによる
コメントを追加
Hi infoservis112! Did you ever get it to work using above answers?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
infoservis112 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 6,421
