メインコンテンツにスキップ
The GE Profile Tri-Temp is a free-standing water dispenser with an integrated chilled compartment.
52回答 すべてを表示
The middle spout is leaking
Middle spigot is slowly leaking. Can I replace the washers?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Similar problem with cold water spigot. Slow leak - any ideas on how to fix this?
さんによる
コメントを追加
2件の回答
最も参考になった回答
my watter bottle dispenser is leaking how can I fix it or there is a shop who can fix it
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
where can I take my watter bottle dispenser fix
さんによる
コメントを追加
To tell you the truth, about all that you can do is swap a non leaking spigot stopper with one of the others and tie off the line of the leaking spigot. They don't seem to make the spigot internal stopper anymore (I can't find it) and I just tried to grind down the stopper arm to make a tighter seat and that doesn't work either. To take to top off, turn the bottle collar to loosen and then lift off, two screws in the top back corners and then the lid slides a little to the front to release, you can then see the inside where the spigots are. Where the stopper assembly arm goes into the spigot, that portion can be unscrewed and you can then see the internal spigot stopper,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Pete Tavares Jr さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,981
