My battery dies quickly, how do I replace it?
If my battery dies quickly is there any way to salvage my battery or should I replace it, if possible.
If you are using a Motorola brand charger, and the battery is dying quickly, first check to make sure that you don't have applications running in the background that may be the cause. If you eliminate the charger and the programs from the equation, you'll need to replace the battery. Fortunately, the battery can be replaced. If you need to replace the battery, follow this link for instructions:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 58
