Battery not Charging , Its now not powering on
My one plus two is not charging its now literally dead , i cant charge with any charger
OnePlus' second entry into the Android phone market, the OnePlus 2, was released on August 11th 2015.
1.If it won’t turn on then leave it plugged in for a couple of hours, and then hold down the Power button for a good 20 seconds to see if it comes back to life. OnePlus suggests that you try holding the Power button down for 20 seconds five times to power cycle the phone.
2.Try plugging it into your PC and see if it’s recognized or if it charges.
3.Try holding down Power and Volume down and see if it boots into recovery mode.
If nothing works, you may have to repair it.
コメント:
The data cable works for data transfer (when there is charge in phone) but not it totally empty . Left it plugged for hours but nothing working .
arevindh さんによる
It looks like your battery is damaged or otherwise faulty,maybe the best fix is to replace the battery itself. You can find repair guide for the battery replacement.
Witrigs さんによる
My data cable is not connected with PC it is only charging from PC. As well as my charger is not working.
dummyuser3forsocialiq さんによる
Thank you so much. My OnePLus 3 went to a comma and i got a heart attack.
The 20 Sec power button hold worked for me
Thank you.
Faiz t さんによる
THANKS! a lot! hold down 5 times for 20 secs worked for me
vishvanath さんによる
got a problem with my OnePlus2 phone. could not power although there is a 87% of battery.. try every step i know.. hold down the power button 20second 5times nothing change. open the back cover unplug the battery connection wait for 20seconds plugin back. so far nothing change.. does any one how to fix this issue..
コメント:
Have the issue. Tried all those manipulations with buttons holding, unplugged the battery, changed charging cable, changed battery, changed USB flex - this piece of crap is completely dead...
Yaroslav Kutovoy さんによる
I had the same problem a week ago. Battery stopped charging even after it was plugged in for hours. Took it to a service center which found that charging cable was faulty. Replaced with a new cable (Amkette Power Pro USB Type C) and now it charges surprisingly very fast - faster than it used to charge with original one plus 2 cable (red flat one)!
コメント:
Hi! Did your phone accidentally turned off? Or it just stoped to take charge? I’ve been trying to charge mine with nexus 5x charger, but it didn’t help.
Too late to reply! In any case my phone never turned off accidentally. Due to faulty cable, phone charging was terribly slow.
Vidyasagar Mundroy さんによる
評価: 1
I have the same problem, but it seems that there is a short circuit on the connector usb-c on the phone. When connected to an external charger (quadruple), two telephones, including my other phone stops charging. Cable tested, the original charger as well. So only remains connector. Phone bought on the website two months ago ... as it advertise?
評価: 1
Even i am having the same issue with OPT..its literally dead. When i press the power and volume down button it just flashes and switches off..And if power and volume up button it goes into fastboot mode. Rest nothing is working. Please help..
評価: 1
I thought it was a hardware issue too but I started to look more into the OPT issues and find out that was hardbricked so you could try to find a guide for unbrick it. If you dont find it tell me and i'll link the web. I've recovered mine from the death:)
コメント:
can you send me the link
tharun kumar さんによる
send me the link plz
Er Raj さんによる
Please tell me the option...I am into a situation where my OPT doesn't power on...but always shows low battery...basically stuck.
Kavitha Rajiv さんによる
can u please send me the link
Rohan さんによる
please send me the link at email ID ritavparikh@gmail.com
ritavparikh さんによる
For anyone with bricked problem Try one plus forums. They got answers.
Also check with other another type c cable bcz itit solved my problem
コメント:
Yesterday I replaced my battery, works good over night phone is dead it doesn't want to power on again, what can I do.
marla boos さんによる
評価: 1
評価: 1
評価: 1
I recently had the same problem where the OPT used to charge extremely slowly. One of the solution that worked for me :
1)Switch off the phone.
2)Press the power button and volume button simultaneously.
3)Now a screen will pop up.
4)Clear the cache memory.
5)Reboot the phone.
That's all. The charging improved a lot. Hopefully this will work for others as well.
評価: 1
評価: 1
There are various "answers" to this issue, and many of them sound suspiciously like voodoo. What is causing the issue with the battery / power? That might help. In my case, the phone went from intermittently starting, even letting me root the phone and use it for an hour or so, to gradually getting worse and worse as far as even starting at all went. At present it does not start.
Here are the more believable, from my point of view, possible reasons this is happening.
1. The battery has gone bad. (This may be in part true, but it is doubtful it went this fast.)
2. The charger and/or cable is bad. (I'm open to this, but have tested the charger on another phone. I don't have another usb c type device to test the cable on.)
3. The software is bad. (I tried two completely different operating systems, the default one and Lineage Oreo; both failed to continue running.)
4. The internal usb c ribbon assembly has gone bad / has a short in it. (I am considering buying a third party one of these off ebay - they are cheap and relatively easy to remove / replace - to find this out).
5. Some other short circuit / electronic issue is at fault.
If anyone else has this issue and sorts it down to a *cause*, I'd sure like to know about it.
過去 24時間: 1
過去 7 日: 15
過去 30 日: 72
今までの合計 41,323
My one plus two mobile is taking more hours to charge.it taking 8 to 10 hours for full charge.what i would do????
anandraj9022 さんによる
Im having the same problem. i even replaced the battery and still it turns on and switch offs immediately. please help
fathimath umaina さんによる
Lots of problem with battery of one plus two phone
Laxman さんによる
It says I need to turn my USB thing on to charge my phone where is that????
Eamon さんによる
