メインコンテンツにスキップ
The 3000GT is a sports car manufactured by Mitsubishi between 1991 and 1999. Outside of the United States it is known as the GTO. This category covers all three of its generations, 1991-1993, 1994-1997, and 1997-1999.
2回答 すべてを表示
ECI Fuse blows randomly.
Hello! I own a 1997 Mitsubishi 3000GT SL. For the last year or so, whilst driving a relay fuse that is under the hood only named ECI is blowing. It seems to happen randomly, but the higher the RPM or the farther down I have the gas pedal pressed, it blows. The fuse is a 20a fuse if I remember correctly. I havent been able to find anything on this issue in other forums. Now, when the fuse blows. Its almost as if the Fuel Pump shuts off, and the engine is getting no fuel. Spark is there, no fuel though. If anyone has any helpful information it would be greatly appreciated! Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Found this link which has info that may be of relevance to your problem, especially the 3rd post on the page.
http://www.3si.org/forum/f11/what-does-e...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ace TroubleShooter さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 2,244
