メインコンテンツにスキップ
Repair and disassembly guides for Magellan GPS devices.
20回答 すべてを表示
My Magellan GPS 9250T-LMB wont come on
I was on the road, my GPS was working. I unplugged the power cord from the car outlet. 5 minutes later, I plugged it back in, but my GPS won't come on. To check if the cord got bad, I checked another cord, but the GPS won't come on. I opened the GPS and checked the voltage of the battery. It shows 3.7 volts. Please tell me your opinion on the problem. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント:
Hi,
Have you tried resetting your GPS?
To Reset: Slide the power switch all the way over to the left and hold for 5 seconds. Release then try to turn on your GPS
さんによる
es i tried slide power switch to the left like you set, but it still it not come on
さんによる
I have the same problem and the reset did not work!
The light that shows it is plugged in to power is the only thing that works at all. How can I make it come on again?
さんによる
コメントを追加
1 件の回答
Charge your GPS overnight take a paperclip pushing the reset button hold it for 8 seconds release it hold the power button for 8 seconds then release it that should make it come back on if it does not you need to replace the battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
roleg1313 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,287
