Something is stuck in my headjack.
I can't tell exactly what it is, but my headphones won't fit in all the way. Is there a way to open up the phone to remove the obstruction?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Take a wooden toothpick and try to clean out the jack opening it up wont allow access unless you intend to replace the jack which will probably be whats necessary to repair it unless you can get it clean
このアンサーは役に立ちましたか?
dont stick anything metal into the jack
Try making a q-tip really small coat it with isoprpal alcohol and use it to clean out the hole
このアンサーは役に立ちましたか?
Why are you just repeating what has already been posted?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 104
