Gas mileage really sucks?
It sucks gas I know it's a 350 with full time four wheel drive but I should be getting more than 4 mpg
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I'd take it in to an AutoZone and get a free computer readout to try to see what's wrong. Also see if the the four wheel is engaged all the time.
このアンサーは役に立ちましたか?
Hi,
Maybe you should consider a tune up for your vehicle. Google how to tune my chev pickup.
このアンサーは役に立ちましたか?
you can save serious gas mileage get a set of warn hubs so you can technically be running 2 wheel drive you can unlock and run too high also it's probably a good idea to tune up your engine spark plugs fuel filter oil change air filter PCV valve check your timing. It also might not be a bad idea if you have a full-length exhaust maybe not in good shape to possibly put a set of good free flowing headers on there. also rebuild your carburetor and make sure you have it dialed just right.. Also don't forget to change your cap and rotor
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 145
