メインコンテンツにスキップ
Support for desktop computers by Gateway. Gateway is owned by Acer these days, and anything new by Gateway is supported under the Acer Group.
37回答 すべてを表示
How do I swap hard drive from a Compac to gateway desktop
Steps on how to swap a hard drive from a Compac to Gateway desktop
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Gary Reeves Sr what model Compaq and Gateway are you looking at? Do you have a model number on either one of the hard drives?
さんによる
The gateway is a dx4860-ub32p desktop, it has no hard drive. The Compaq I have to chk the model.
さんによる
Compaq model is CQ5320Y
さんによる
コメントを追加
2件の回答
選択されたソリューション
Assuming it is an SATA compatible drive, remove the drive from the compact, attach it to an adapter or use and external enclosure, use your disk utility to reformat it and install a system. Drop it in.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
If you intend for the hard drive to run you OS then you will need to format and reload you OS after the switch. the system wont work from one to the other.it will only work on identical systems. however if you are using the hard drive for storage only and not trying to run an OS from them then simply swapping them in as an auxiliary drive is fine making sure to activate them in drive management . heres an instructional video on the hardware end
https://www.youtube.com/watch?v=5lVnFlFr...
Hope this helps
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Gary R Sr さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 237
