メインコンテンツにスキップ
Samsung製のラップトップ用修理ガイド
345回答 すべてを表示
550P5C screen hinge is broken.
One of my laptop screen's hinges broke which makes the lower panel of the screen borders jut out. This has no apparent damage to the screen however when i open or close the laptop the hinges make a cracking sound. How much would this cost to repair?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Hi,
I want to post this somewhere because it might be helpful to others. I also had the Samsung Notebook hinge problem. When I took it apart the screw insets for the hinges and plastic clamshell were broken, but upon inspection in became clear that the main problem was that the hinges had gotten stiff to the point where it was very difficult to flex them even with pliers. It was clear no repair would work unless the hinges were replaced or made flexible again.
I tried, cleaning with alcohol, acetone, lubing with light oil etc. but no joy. But under microscope I could see small hairs sticking out between the disks that make up the hinges, I thought that crap must be gumming up the works. So anyway, here is what did work. Heating the hinges in the flames of a gas stove for about 5 minutes to burn all that crap out. In my case that involved first cutting away a plastic sleeve over part of the hinge so that I was only heating metal, and then replacing it with electrical tape. After this treatment, and then the application of a little light oil, the hinges worked at expected and I have a repair that should hold.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Fantastic.So pleased I came across your post. Worked perfectly with a blow torch in moments! Who would have thought of looking at the hinge under a microscope - but you, obviously.
さんによる
コメントを追加
HI,
My mates chromebook doesn't shut. The hinge is broken I think and I need to return it in 10 days what do I do?
Thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
The Mexican Gnat さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,414
