メインコンテンツにスキップ
グーグル5番目のネクサスフォン。2013年10月31日に正式発表され、4.95インチ1080pディスプレイ、2.26GHz Snapdragonプロセッサ、LTEをサポート。Android 4.4.2、KITKATを搭載。製造はLG。
222回答 すべてを表示
My Nexus5 restarts every 5-10seconds - what's the problem?
My phone restarts every 5-10 seconds. I had this issue before and back then pressing the power button multiple times until the phone had fully booted fixed it. However, this now only helps to prolong the time until it reboots for a few seconds, but isn't a fix anymore. Is it a power button issue or a software issue? (The problem started (like the time before) right after the last software update)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
Here are some troubleshooting tips
You can put your nexus in safe mode :)
Nexus 5 Troubleshooting
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I've had the endless boot animation problem before, it's hard to tell if an application's data is causing the issue, or an app itself. I don't believe there's a way to boot into Safe Mode from bootloader. I'm afraid your arguably easiest fix is to factory reset it and configure it again.
Sometimes when a Nexus is stuck in bootloop, I'll hold the POWER button down until the screen goes blank again, and without releasing the POWER button, hold VOL DOWN.[1] That may get you into bootloader. From there enter Recovery, and in Recovery you can factory reset it. It should boot normally and then take you through setup.
[1] Google's information for the Nexus 5 states that bootloader is reached with both VOL UP and VOL DOWN along with POWER, but my refurbished unit works with only VOL DOWN and POWER.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I've read since buying a Nexus 5 that there is a well known fault with the power button being faulty due to dirt build up. Rebooting every 5 seconds could indicate the power button being shorted, and acting like it's being held down continually.
You can pop the cover (see the tear-down guide) and clean it, or buy another. Obviously booting up and back into safe mode isn't possible if you can't even finish booting up due to incessant restart.
さんによる
コメントを追加
回答を追加する
Ella さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,529
